VW parts versus Festiva parts
Checked the mount spacing on the rear axle beam of the Golf versus the Festiva/Aspire units, it's a no-go. It could be done easily enough, but it's completely pointless, as the VW rear brakes are smaller than the Aspire parts, and the Aspire parts have the same bolt pattern as the VW, so there's no reason to use the (heavier) VW rear beam unless I were interested in maybe changing the suspension characteristics, etc... but everything looks to be in mostly the same places, too.
Originally posted by Movin View PostI was hoping you were not counting on that notch to hold it in place
You have it thought out well!!
I always "know how" to make things work, just usually don't have the gumption to do it.
Oddly, the computer didn't mark "gumption" as a mispelled word. O.o
Originally posted by Movin View PostChrist..you may need split bushings for proper clamping through to the festi stud..
2 piece ones would be workable, too, since you could then reuse them for ball joint changes. However, for the "mockup" project at least, and so I'm not asking too much of anyone, it'd be easier to just drill an existing slug to make the bushing, then I can bandsaw it later or get another set made for the "permanent install".
fsta..wood gas??? that is the only thing more carbon neutral than electric plug in
that I know unless you charge off the grid..wind or solar..?
Will follow the thread for sure. I looked into a vw swap as well but ended up going totally custom with a non-fossil burning festiva.
Originally posted by fstamand View PostA few notes from a mk1 "dub head"
mk1 (pre 84 and mk1 cabriolets) didn't have any subframes. Swapping the LCAs would be a pita especially the sway bar, which is oriented via the rear of the car vs the front on the festiva.
Ball joints have different sizes between mk1 and mk2, perhaps one is closer in size to the festiva.
mk2 hubs are better in a way since they accept bigger bearings. however the strut tower is not directly interchangeable between mk1 and mk2. The mk2 struts would be too tall for a festiva. The mk2 struts do not have the upper two bolts found on the mk1 and festiva
Also note that although quoted to "swap to gti rear discs", the majority of mk1/mk2 GTIs had 4x100 drums. The 16V model had 4x100 rear discs; a problematic swap since they are complete junk. The handbrake assembly is also very different than the festiva.
The stock mk1/mk2 diesel had 55hp (ish). Slow as molasses.
A turbo diesel 1.6 can be found and "tweaked" to get a little more ponys, but still painfully slow.
the mk3 models had a 1.9 TD, a very nice upgrade (almost bolt on !) but had many problems with the crankshaft timing pulley shearing (auto destruction).
The trannies for all these models had crappy linkage design (overly complicated). A common swap is from a passat or later mk3 with cable shift. Bolt on to the diesels and turbo diesel models; although a mount needs to be fabricated.
A common swap for rabbits is to swap in corrado brakes (adapter needed). These brakes are HUGE: 11" and require a minimum 15" rim. This would be impressive to see on a festiva.
good luck! Anything is possible I owned mk1, mk2 and festiva; it is my honest opinion that the braking and handling of the early volkswagens are much better (and easier to maintain) than the festiva.
My intention is to use the LCA's from the Festiva, including the installed ball joints, and use the VW MK2 hubs. The only MK1 part I intend to use are the axles, because they're physically shorter than the MK2 by something like 1.5" per side (about 40mm) and the MK1's chassis width is closer to the Festiva.
The N/A diesels can be boosted fairly easily even using the stock pump with a little care of the weight of your right foot. The piston squirters in the turbo blocks are proven not necessary for low boost levels or people like me who won't use the boost excessively. Best to mind EGT's while boosting, in any case.
The 55HP of the diesel is actually sufficient for a Festiva, given that the stock engine is about 63HP and has very little torque, versus the relatively flat and higher torque curve of the diesel. There's obviously some added weight, but it still won't equal the overall weight of the MK2 installed in the Festiva.
To counter to issue with the shift linkage (crap... total crap) I'm just going to get a twin cable shifter and make brackets for the cables to mount to the trans directly at the gear manipulation shaft/lever. I can account for shift throw at the shift lever itself by moving the cable connection points, or at the transmission in the same way.
Thanks for your input. Follow this thread, I may end up with some questions that require your knowledge!Last edited by Christ; 04-29-2012, 10:28 PM.
The only issue with working in winter is temp, because I have a semi-indoors location to work on it, and can heat it with an outdoor heater.
Funding is a bit of an issue, but I can work around it for the most part... there shouldnt' be too much that's cost-intensive other than ball joint sleeves and whatever set of axles/modification I need.
The only difference between MK1 and MK2 axles is the tube length, and my Golf's axles were junk, so I'll put the inners and outers in, then measure the distance once everything is in place to figure out if MK1 axles will work.
Anyone here have machining experience/access and feel like turning a set of bushings "for the cause"?
I'm not sure about the dimensions, but it would be the OD of the Festiva ball joint as ID, the ID of the VW knuckle as OD, and the length of the Festiva ball joint stub or slightly longer. I can get exact measurements if anyone's interested in making them for me.
Sounds more than great that this is starting in spring not fall as I glance at members location
Ok, I decided I'm gonna say screw the BP swap and work on this...
So the idea is that when I get rid of the chassis for the red Festiva, I'm going to keep the front clip for mock-up purposes, put some kind of stilts under it, and move it to a more usable area of the yard.
I'm gonna start out with getting the VW knuckles mounted, but this is going to be a VERY slow project... i.e. When I feel like doing something pointless, or between other jobs for the day.
When I get started on it, I'll take pics along the way and start a new thread to document it.
Originally posted by getnpsi View PostYou ever sprain an ankle along the way? Christ on a crutch!
I've actually had bar-goers ask me if I could walk on water. The usual response is "No, but I could sure walk on some beer...." which generally gets me a free drink or two.
A slightly more depraved Jesus joke that I encounter regularly is
"Water to wine?"
Nope... Horse piss to human piss. (I apologize if that's too graphic, feel free to remove/censor if necessary.)Last edited by Christ; 04-27-2012, 02:15 PM.
I just assumed you were a Capricorn who eats organic foods.
(free reps for anyone who knows where that reference comes from)
