A few notes from a mk1 "dub head"
mk1 (pre 84 and mk1 cabriolets) didn't have any subframes. Swapping the LCAs would be a pita especially the sway bar, which is oriented via the rear of the car vs the front on the festiva.
Ball joints have different sizes between mk1 and mk2, perhaps one is closer in size to the festiva.
mk2 hubs are better in a way since they accept bigger bearings. however the strut tower is not directly interchangeable between mk1 and mk2. The mk2 struts would be too tall for a festiva. The mk2 struts do not have the upper two bolts found on the mk1 and festiva
Also note that although quoted to "swap to gti rear discs", the majority of mk1/mk2 GTIs had 4x100 drums. The 16V model had 4x100 rear discs; a problematic swap since they are complete junk. The handbrake assembly is also very different than the festiva.
The stock mk1/mk2 diesel had 55hp (ish). Slow as molasses.
A turbo diesel 1.6 can be found and "tweaked" to get a little more ponys, but still painfully slow.
the mk3 models had a 1.9 TD, a very nice upgrade (almost bolt on !) but had many problems with the crankshaft timing pulley shearing (auto destruction).
The trannies for all these models had crappy linkage design (overly complicated). A common swap is from a passat or later mk3 with cable shift. Bolt on to the diesels and turbo diesel models; although a mount needs to be fabricated.
A common swap for rabbits is to swap in corrado brakes (adapter needed). These brakes are HUGE: 11" and require a minimum 15" rim. This would be impressive to see on a festiva.
good luck! Anything is possible I owned mk1, mk2 and festiva; it is my honest opinion that the braking and handling of the early volkswagens are much better (and easier to maintain) than the festiva.
