Can KYB GR2 struts for Festys be installed on Aspires (front and rear), with the stock Aspire springs? I know the spring diameters are the same, but how about the placement of the brake line mounts, is this a problem? And does the longer Aspire spring cause any issues, such as maxing out the strut extension??
I am not concerned about the lower spring perch issue on Festy-spec rear struts; I will probably just go to narrower tires to solve this.
