So, let's take some 1/8" 1.5" angle and some 3/4" 0.120 4130 chromoly tubing, also four 12mm bolts with nuts.
If we cut four pieces of angle & drill some holes so that we can bolt pieces together:
Weld two of these angles to the torsion beam
We can than weld the tubing between the other two angles - and call it a sway bar. I hope we can,
Still need to paint this orange.
but that probably would not happen
