Originally posted by MrFishah
2003-2005 rio has larger brakes...
What year Rio tie rod ends are you using.Last edited by nitrofarm; 07-16-2012, 04:18 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
No, not at all! I just know that the proportioning valve is meant for the stock brakes. Upgrade to Aspire parts, and they're designed to once again work in the same manner. If you change your rotors up front to a larger diameter than stock without upgrading your rear drums to Aspire or swapping it out with EGT or Capri or that VW swap, you throw the proportions get thrown off.Originally posted by rbrown View PostWait what? Are you saying the brakes would be too strong for the little Festy?In love with a MadScientist!:thumbright:
As stated above by Russian, the Rio tie-rod ends are the same (According to AutoZone/Napa/Orielly/Etc) whether the Rio is a 2001 or 2004. These are the same tie-rods that fit the mid-90s Aspire.Originally posted by nitrofarm View PostWhat year Rio tie rod ends are you using.
In our case, we purchased Outer Rods from a 2001 Rio and Inner rods for a 1993 Festiva.#33 Ford Festiva "We Are Not Really From Iran" - 24-Hours of LeMons 3x Trophy Winner & Class B Winner
Ok. My plan. Swap Aspire rear, Rio front, new Festy master cylinder, new hoses.Originally posted by DriverOne View PostNo, not at all! I just know that the proportioning valve is meant for the stock brakes. Upgrade to Aspire parts, and they're designed to once again work in the same manner. If you change your rotors up front to a larger diameter than stock without upgrading your rear drums to Aspire or swapping it out with EGT or Capri or that VW swap, you throw the proportions get thrown off.
I guess I will see if it gets twitchy or have lock-up problems.Rodney
1991 FI 5 Speed Aqua Blue
Which Rio?Originally posted by rbrown View PostOk. My plan. Swap Aspire rear, Rio front,
rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
It's cheaper as well as an upgrade to use the 94 Protege BMC instead. You will immediately feel the improvement. The Protege BMC is the same as the EGT BMC (YMCA, LOL, BRB, WTH, FTW!) Although it uses an external proportioning valve instead of an internal one like the EGT which needs to be blocked off in order to function properly.Originally posted by rbrown View PostOk. My plan. Swap Aspire rear, Rio front, new Festy master cylinder, new hoses.
I guess I will see if it gets twitchy or have lock-up problems.In love with a MadScientist!:thumbright:
Noted.Originally posted by DriverOne View PostIt's cheaper as well as an upgrade to use the 94 Protege BMC instead. You will immediately feel the improvement. The Protege BMC is the same as the EGT BMC (YMCA, LOL, BRB, WTH, FTW!) Although it uses an external proportioning valve instead of an internal one like the EGT which needs to be blocked off in order to function properly.Rodney
Ok cool,I thought there was a difference. Perhaps I'm thinking of the extra length thats on the knuckle where the the tie rod joint drops into. There is a reason why folks havent used the Rio Knuckles yet.IIRC it puts the inner/outers at an angle,as oppossed to being inline with the rackOriginally posted by MrFishah View PostAs stated above by Russian, the Rio tie-rod ends are the same (According to AutoZone/Napa/Orielly/Etc) whether the Rio is a 2001 or 2004. These are the same tie-rods that fit the mid-90s Aspire.
In our case, we purchased Outer Rods from a 2001 Rio and Inner rods for a 1993 Festiva.Last edited by nitrofarm; 07-16-2012, 11:19 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
So I'm sure there are lots of people reading this thread who are interested in using the 03/04 Rio Spindles to gain the extra brakes.Originally posted by nitrofarm View PostPerhaps I'm thinking of the extra length thats on the knuckle where the the tie rod joint drops into. There is a reason why folks havent used the Rio Knuckles yet.IIRC it puts the inner/outers at an angle,as oppossed to being inline with the rack
Do you have any links, documents, or specs to support this claim of an incorrect angle? Do you know somebody that's tried and failed? If we aren't sure of something, lets wait until we are so that we don't mislead others.
We will have the 03/04 Rio spindles ready to install shortly and we will report back with our findings (hopefully definitive answers to the wheel bearing issue and the tie-rod angle issue).#33 Ford Festiva "We Are Not Really From Iran" - 24-Hours of LeMons 3x Trophy Winner & Class B Winner
http://www.fordfestiva.com/forums/sh...ad.php?t=41641 see post 100,122 etc MrFishah this thread is located in the "Custom Suspension,Brakes & Wheels".Its on the first page just a few threads below this one.Sorry I mislead you wont let it happen again.Originally posted by MrFishah View PostSo I'm sure there are lots of people reading this thread who are interested in using the 03/04 Rio Spindles to gain the extra brakes.
We will have the 03/04 Rio spindles ready to install shortly and we will report back with our findings (hopefully definitive answers to the wheel bearing issue and the tie-rod angle issue).Last edited by nitrofarm; 07-17-2012, 01:43 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Thanks for posting that link. Sorry if my post made me come off sounding like a dick, I just wanted to make sure nobody else goes and buys something that might not work.
That other thread is a great read. I'm still thoroughly confused though lol.
We will report back with updates and pics as soon as we're done. Thanks!#33 Ford Festiva "We Are Not Really From Iran" - 24-Hours of LeMons 3x Trophy Winner & Class B Winner
Yep, I remembered Rectilinear had done the Rio knuckle swap. I'm planning on doing this swap to Prettystiva.
However, I read somewhere on here that the '03 and later knuckles were different and would not work.
I have not confirmed that myself, so press on and let us know!
A "bigger brake" upgrade would please some folks. Maybe even me!
Its all good let us know what you find.Originally posted by MrFishah View PostThanks for posting that link. Sorry if my post made me come off sounding like a dick, I just wanted to make sure nobody else goes and buys something that might not work.
We will report back with updates and pics as soon as we're done. Thanks!Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Ha I was going to bring up this other thread too.Originally posted by nitrofarm View Posthttp://www.fordfestiva.com/forums/sh...ad.php?t=41641 see post 100,122 etc MrFishah this thread is located in the "Custom Suspension,Brakes & Wheels".Its on the first page just a few threads below this one.Sorry I mislead you wont let it happen again.Rodney
