Russians disc brakes on Aspire rear mock up
  • Russians disc brakes on Aspire rear mock up
    The Russian stopped by to check clearance on his disc brake bracket on the Aspire rear end. Looks like there should be plenty of clearance. Im hoping we can get a EGT ebrake cable to work on the set up.
    How much does the track width increase with that setup?
      i dont think its going to be much, maybe less then a 1/8 of a inch. his bracket goes between the spindle where the drum backing plate goes which was maybe 1/16 of a inch. his plate i believe is a 1/4 inch. maybe he can chime in.
        Hot wheels, I think you may have to grind the corner of the beam where it comes close to the shock. I had to do that because the beam was hitting the shocks and dented them. It happens when your hitting bumps under body roll conditions.
        It may not be a problem on the aspire beam, but it hit's on a festiva beam, that's why the factory shock has skinny extension on it.
          are you using the escort gt spindles and hub's?
          -1991 L 238k AC/Cruise Josh's future DD from neanderpaul, the clean slate!
          -1991 GL 171k AC/Rust free Jake's future DD (thanks kevin!)
          -1993 L B6T swapped auto(thanks rob!) 88k was 123whp 15.8 at 87mph currently undergoing surgery
          -1989 LX crazy project car you'll all see one day! (hopefully fm8 )
          Have one hydro g and xr2 mid shaft for sale super cheap! PM me!
          we have owned 10 of these cars to date and we're only 20 hahah.. call it an obsession!
            nop there cut down drums with the stock aspire spindles. essentially the drum has been turned into a hub.
