323 parts
  • 323 parts
    Hi all I am new, and I am wondering what parts are swappable of a 1986 323 to a Festiva. I know the engine is a bolt in, I am also curious about the breaks. I read that the front breaks can be swapped?
    I am also wondering if it is worth it, or if the breaks that FMS has for the Festiva ( slotted rotor set) is any good? Are they vented, and of larger diameter then OEM?? Also what about the rear breaks.
    Also what is the OEM bolt pattern on the Festiva?
    Thanks, Ted.
    When all elce fails Duct-Tape provails
    Re: 323 parts
    Check to see if it has intermittent wipers. The module will swap. The brakes won't, get them from an aspire. Those are an easy swap.
