Are all years of aspire wheel bearings the same? I can't remember what year aspire I used for the brake swap on cream puff. The new owner is having front wheel bearings done. thanks
I'm pretty sure all Aspire and Festiva front wheel bearings are the same. I'm also pretty sure the rears are the same too.
If you're worried, look up the parts numbers at Rockauto from the comfort of your computer chair.
I just did: BR1 and BR4 rear for both; BR11 for both fronts for both. A1 and A4; plus A14 (?) (I forgot already!) for both fronts. (Two different companies, thus two different part numbers.)
Both same same on front and rear.
FYI, I think Kia Rios are the same fronts, but only one set in the rear is the same (inners, I think).
KarlLast edited by Safety Guy; 11-07-2012, 10:18 AM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
Yes, one each of 1 and 4 for each side in the back, a pair of 11s for each side in the front for all years festivas/aspires. Make sure he knows what he's doing, or has a shop that does. DO NOT lose or mix up the spacers!No festiva for me ATM...
Well Paul, I'm not a Pro but I can bark like a dog!
Arf,
