Lowered the Festy even more...
  • Lowered the Festy even more...
    Messing around with different tophat ideas to get more travel while still being low. The pinch weld is right at 3in of the ground. You can see the roof line is level with a stock f150 bed! I have the rear pretty high in the pictures though, can't lower the rear much more until I mount the flares or extreme rubbing will occur with my offset. Here's a few pics...
    Then drove across the yard and well....raked up all the leaves :p
    '93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
    That is so MAD TYTE JDM HELLAFLUSH BREH ILLEST FATLACE FOR DAYZ
    14 C7 Z51
      Weeks son weeks!!!!!! LOL
        WEKSOS? What is weeks?
        14 C7 Z51
          Needs rear camber..
            Originally posted by EVOGUN View Post
            Needs rear camber..
            Do you know where I can buy some??? :p
              Re: Lowered the Festy even more...
              Suspension Parts and More for Your 1997 FORD ASPIRE at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.
              There you go. :p
              Sent from my C771 using
              Better Than Nothing Racing
              Way too many cars
              :woc:
                AHAHAHAHAHAHAHAHAHAHAHAHAHAH!!!!!!!!!!! LOLOL!!!!!
                  whats the specs on those rims and tires? looks mean!!
                    i have a pair of skunk 2 coilover on my festiva and it rides rigid, do you have any suggestions to reduce the slamming? thanks in advance
                      either better dampened shocks/struts or just cut some stock civic springs and throw em on
                        drool
                        Mike, AKA the sasquatch
                          Sweet Foliage!
