front knucke & rear hub questions
  • front knucke & rear hub questions
    Has anyone compiled a front knuckle list with matching spline count ect... for swapping out breaks and what I know there is a list compiled (http://www.fordfestiva.com/forums/sh...azda-Brake-FAQ) but it has no mention about Knuckles or rear hub compatibility that would bolt to the stock festy rear axle Please help!!!
    Mercury Capri and BF chassis Mazda 323 front knuckles as well as Kia Rio and Ford Aspire. Nothing directly swaps to the rear without changing the beam or fabrication that I know of.
      We need to have info like this ALL IN ONE PLACE, like a spreadsheet that can be downloaded.
      Not only what non-Festy parts fit where on Festies, but part numbers of new parts that fit that don't come up when McParts stores look up something. I remember when I had my Amphicar that I had to buy parts using numbers I got from the guy who bought the remains of the factory. It was not uncommon for, say, a Mercedes dealer to look up something with a number I gave him and tell me "It has no listed use, but we have 17 of them on the shelf that you can buy." The 3,800 Amphicars were produced from a hodgepodge of parts from all over Europe, including a TR-4 engine. Things like ball joints were the same as on old Mercedes models.
      BTW, I talked to "the old guy" at a local NAPA store recently when buying LCAs (they had two in the local distribution center) about when NAPA is going to ditch the Festy. His response was "Never. It will be when our parts-making suppliers decide it's not worth it anymore and THEY decide to stop." If all the stores use the same suppliers (which I would think is likely), then we may find some morning that EVERY store has stopped offering a given part, at least until their invetory is depleted.
      I'd really like to stock up soon on critical parts (think things like $10 "brake little parts kits") to keep my "fleet" going for another decade or more.
      I know this has been discussed a bit elsewhere.
      88L black, dailydriver
      88LX silver a/c, dailydriver
      4 88/89 disassembled
      91L green
      91GL aqua pwrsteer
      92GL red a/c reardmg
      1952 Cessna170B floatplane
        Why? So all the newb's can ask questions to which the answers are already provided? If people actually did research, spreadsheets wouldn't be asked for
        But if you could hook a printer to my head on all the things possible to a festiva......
          what years of kia rio and 323s work
            Damkid,
            No, so people do NOT have to ask questions and/or do all the research themselves.
            I spent several hours last week reading through years of posts on this site regarding sway bar to radiator bushings. I think (but I'm not sure) that the only real source is in Australia. I was NOT able to come up with anything conclusive regarding rear beam attach point bushings.
            It would be so nice to be able to go to a single online reliable source for this kind of info, where the info has been verified or could easily be verified by other members.
            Also, I have my own paper files of info I've gathered during my 12 years of Festiva ownership, most of which I've never posted as individual posts to make available to others, but would add such a master spreadsheet, or cross-check my info against what others put into the master list.
            91L green
            91GL aqua pwrsteer
              It would work just like the sticky about no /low heat. I have seen that question asked about 6 times in the 8 months I've been on the forum. I feel sorry for people who have been on longer.....
              06 Jeep Cherokee Overland
              95 Aspire (sold)
                When the production stops companies such as RARE PARTS may buy all the remaining inventory they can find, usually at a discount because
                parts stores need to clear obsolete parts so that inventories and computers are happy. These same companies will then keep selling parts but at
                a higher rate, much larger mark up than normal.
                The more we find new parts from other sources the better, rio parts, parts from Phillipines and other counties the better.
                  Not to be a complainer Damkid but #1 I'm not a noob check my join date(just because I'm a junior member dose not make me a noob) #2 I did the research (since i joined in 2010) and there was nothing definitive and or complete that I found in one single post and I just wanted to crosscheck with a active member & have a definitive answer before I went and spent money for parts that I wasn't 100% sure on.
                      Thanks for the help
                        so the BH Mazda front knuckles won't work???????? (1994 - 1997 Mazda 323/Protegé)
                        '90 L-Plus 420,000 miles , rusting hard and going to the chopping block
                        '97 Honda CR-V , 91,000 miles and just starting its journey
