I figured id post this because i like posting when i work on cars. It makes me feel better about myself.
So getting into the reason you opened this Post.
I recently bought and painted these.
I love them, there bigger, wider, and have more grip then the stock festiva rims.
But there is a down side. Because the inside locating ring in the rim isn't very close to diameter of the wheel hub it means there is slop in mounting the rim, there is also slop in each of the lug bolt holes. Not to mention the thin walls of the bolt holes which makes it difficult to us anything but a deep 14m socket to loosen and tighten the rims.
So here's what i'm working on.
Below is a picture of the stock festiva hub showing the Dimension of the larger ring closes to the mounting flange.
Here is a picture of the Rim im trying to mount
This means there is .506" of slop in the center mounting ring. :nono:
I will be making this at work
Excuse the crude drawing, i drew it on my phone.
After i use this to mount the rim, i should be lined up center to center, then just put the lug bolts in and be good to go. Less chance of wobble = better driving experience.
I imagine ill use some bar stock steel lying around the shop. Ill keep this updated as i get further.
I know they make these, and normally sell them on higher end rims for there specified application. But i am cheap, and i have access to free stock and machines.
Thanks for reading.
Andrew
Thanks for reading.
Andrew
