I have been running with Toyota 13"x5" alloy wheels for quite a while now. I've had no clearance issues on the back but the front was a different matter. Wheels weights mounted on the inside rim would hit the steering knuckle and strut mounting flange. I was running KYB GR2's all round but changed the rears out to Tein coilovers. As mentioned in another post I discovered that the front shocks were shot so decided to install the Teins up front as well.
There is a lot more "meat" in the mounting flanges of the Teins than on the KYBs. I can't run the alloys because they will hit the strut flange. I have a set of 14" alloys that will clear all suspension components front and rear but with the tires that are currently on them I have serious fender rubbing issues on the rear.
Here's a couple of photos of what I'm up against...
No spacers: steering knuckle hits wheel weights. KYBs were filed down to match knuckle
Tein mounted to knuckle
Amount I would have to remove view 1
Amount I would have to remove view 2
The big question... can I safely remove the material indicated?
I have a couple of options to consider.
1. Retain the 13" wheels, run them with no spacer, modify the strut flanges.
2. Retain the 13" wheels but install a 5 or 6mm spacer. The issue with this is I can't use the universal type spacer as they push the centerbore of the wheel past the hub so would have to purchase hubcentric spacers at a higher cost.
3. Go with the 14" wheels and modify the rear fender area or see if a smaller tire (currently shod with 185-55R14) would eliminate the rubbing.
Your input is greatly appreciated.
Here's the car with the 14" wheels...
And with the 13" wheels...
Thanks
Thanks
