I have these 14x7 rims and wondering if 195/45/14 tires can be mounted on them. checking around on this site I see that 5, 5.5, and 6 inch rims are being used for these tires but no mention of 7in. Can they be mounted on 7 in. rims? If so does any one know the width of these tires. I would like to put these on my 90 Festiva,( stock suspension) but I thinking that maybe 7 in. rims would be to wide. I plan on converting to studs and lugs, and using wheel spacers,but before I spend the money for the tires, studs,lugs, and spacers I would like to find out if these rims and tires would be to wide to put on my car.
14x7 rims
I did mount a rim without a tire on the rear. Although it did not rub or hit anything, it was really close. I'm afraid when the tire is mounted I will have a problem. I don't see anyway to correct this but to add a spacer. As far as the front is concerned I don't know if I'll have the same problem.
Thanks to all for your help and info. Now the search begins for spacers that will fit on a festiva. I guess I'll try some auto parts stores and speed shops in the area. Since I'm sure I will install spacers on the rear, should I also use spacers on the front just to keep things even?
