low posative offset on a festiva?
  • low posative offset on a festiva?
    I found a set of wheels for the Datsun. They happen to have the same bolt pattern as the Festiva. They are 13x6, +6 offset, 4x113. Think they will fit the Festiva, would spacers help?
    Fast....Women are fast
    Quick...Nestle is quick
    I Speak French....in German! lol.
    You shouldn't need spacers with rear wheel drive wheels. They may stick out from under the fender. Normally on these cars a +35 is about right on aftermarket wheels. I'm using 1/4 inch spacers with a +38 offset and 195-50-15 tire.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      They will stick out big time , The front wheels in this video are +15 (that means yours at +6 are 9mm more out) : http://www.shospeed.com/pics/shogun.wmv
        I've been running early '60's Ford Falcon wheels on mine. I don't know the offset but they are for a RWD. No issues with sticking out of the fender or hitting the rear strut.
        But then again I'm running Aspire struts on all 4 corners ....
