Aspire Rear Swap
  • Aspire Rear Swap
    Is there any differences between a 2 door and 4 door Aspire rear end assembly? JY has a 4 door. I just need to make sure there's no issues. Thanks
    93 GL
    probably the e brake cable length would be longer a tad bit.
    www.facebook.com/rhodestiva ;
    rhodestiva@gmail.com ;
    '92 Festiva L M/T
    '93 Festiva GL A/T
      The gas tank will be of no use to you (2 doors share same tank as Festys). You'd think the e-brake would be a bit longer but then again too long is better than too short. Both Aspire parts cars I've scavenged have been 4 door ATXs (autos). Thicker rotors and thicker sway bar than MTX jobs! I used the Festy handbrake cable without any modifications. That's why I can't comment on e-brake cables.
