I did a search, and couldn't find anything, found a couple 15 inch on aspire threads... but basically, with the bolt pattern on the aspire brake swap being 4x100, it opens the wheel options up a little more to my liking... also, going up to a 15 inch wheel open those options immensely.
My question is, does anybody do it? I know going to a 15 is a big jump on something like this, but with the knowledge that the brake swap opens the festiva up to basketweaves from an e30 (14s and 15s [if you're lucky])
I like the idea that it also allows for some other wheels that are 15"s....
What would the ideal offset be on something like this? I saw that on the aspire that it was recommended to stay between 38mm and 45mm offset, but is that the same on the aspire brake swapped festiva?
Here are a couple wheels from e30s specs:
14" bottlecap 14x6" ET33 14.8lbs all non-iS non-iX cars
14" basketweave 14x6.5" ET30 14.3lbs all iS cars and some eS cars
15" iX basketweave 15x7" ET41 ?? all 325iX models
15" Euro basketweave 15x7" ET24 ?? optional on all euro cars
I just want to know that if you do the brake swap, are spacers needed to run the 14" bottlecaps? or if I could find some ix weaves, would they just bolt up? or is there going to be a rubbing issue?
any help/advice would be greatly appreciated! thanks
