My festiva is STOCK. I have the opportunity to get 14" 4x114.3, 6" wide wheels. I apologize, I do not have time to thoroughly research this but my question is, will they fit and not rub? Thanks in advance.
QUICK Response Needed on 14" Wheels
Re: QUICK Response Needed on 14" Wheels
First question that comes to mind is what size tires will you be running?
Sent from somewhere west of here via Tapatalk!Ian
That wheel should fit depending on the offset. And of course the tire size.
165/60/14 shouldn't be an issue and they're easy to find, just mind your offset in the rear.Trees aren't kind to me...
Originally posted by darkfact View PostMy festiva is STOCK. I have the opportunity to get 14" 4x114.3, 6" wide wheels. I apologize, I do not have time to thoroughly research this but my question is, will they fit and not rub? Thanks in advance.
^ true that, what he said is rite on. i have some 14x6 wheels that was on my festy but little did i know that they were about a 0 offset because they were stock wheels off a datsun 510 so they have a rwd offset. i got them under the car with some 165/50s and alot.... alot of fender roll and pucker. so listen to bert and know the offset
The brand is Akuza. These are the wheels.1989 Festiva L Carby
Sounds like they should fit as Geo Metro 13in steelies are an upgrade to the Festiva.
