I have read alot about using spacers to stop the tire rub on the rear. What are you all using for spacers?
wheel spacers
Google wheel spacers.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
There's also "hub-centric" spacers. There's a couple of photos of the ones I bought recently in this thread....Ian
please note: if you use spacers, you MUST use lug bolts that are longer than stock the same distance that the spacers are thick, so 5mm spacer means that the lug studs must be 5mm longer as well.Trees aren't kind to me...
Ian -Originally posted by fastivaca View PostThere's also "hub-centric" spacers. There's a couple of photos of the ones I bought recently in this thread....
Hey, those are cool! Exactly what I need when I mount my tires!
Thanks!88L - 'Twistiva' - 'The Fusion of Man and Machine'
93L - 'Vextiva' - Airport Car
