Whatcha think?
I think it should work just fine.
We'll find out!! Tomorrow I gotta flip it over and do the other side, then get it mounted on a car and find a trailer to pull...
It's 2 1/8" plates front and back, squeezed together tight against the bumper with 4 02Rio head bolts, tacked, beat into shape and welded solid. Then 4 more long thin strips of eighth inch boxing the whole area in. I stuck an old bolt in the pin hole on the backside as a safegaurd. The bumper will be ripped off the rear before this fails, IMO.
Any ideas on how to beef up where the bumper mounts to the car? I also need to get a couple pad eyes welded up somehow, probably use a thicker 3/16 or 1/4" for those.
The receiver is this harbor freight special.. 1.25 -> 2" adapter, I picked it up for 12.99 on sale + a discount coupon.
Before I even put the outside plate on, I stuck the receiver thru the bumper, put two small beads on the receiver to the bumper, and literally beat the crap out of it with a 4lb sledge...it didn't go anywhere, so everything else was probably an overkill. Since I only have a fluxcore welder on hand, I usually do 3 beads on every 90* corner, one in the seam and two on top of that. It's ugly but I know it burns into everything good. I burned thru the 1/8" steel a couple times trying to weld it to the receiver.
