So I have a 93 festiva that needs a swap. Im planning on getting 04 Rio front knuckles, rear axle from an Aspire, Front swaybar from Auto Aspire, and 02 Rio front mounts.
I have read alot, I know 02 Rio knuckles fit but then I have the same brakes from an Auto Aspire. If I get 04 Knuckles I get bigger bolt on brakes. I know I need the Rio/Aspire Outer Tie Rod Ends. BUT will the 04 knuckes fit. I found a post from Russian stating that the Knuckles will fit. Anyone have them installed?
Next the rear axle... Is there a difference between Auto and Manual rear ends? Difference between 2 door and 4 door models? Do all of the rear axles have a "sway bar" built in? Where do I disconnect the e-brake cables at?
Finally for the front strut mounts. Will they replace the Stock Festiva mounts? Do I need anything from the Rio Struts?Spring top plate? If I dont need anything Ill just get the Mounts from rock auto and replace just the mounts.
I am going to get Tein's. Was going to build my own coilovers but I dont want them to be Under Damped. Plus I think I found a kit from HeelToeAuto for like 700 for the coilovers.
If anyone has anyhelp on this swap Im planning on. Can you give me advice? Thanks.
