Can someone tell me which is the top and bottom of these springs ? Does the narrower spacing go towards the top ? Or does it matter ?
FMS lowering springs
Celebrating 25 years of festiva(s) ownership.Tags: None
That's what I was thinking too. But then I saw this video and at 11:25 it looks like the narrow spaced coil go up.http://www.youtube.com/watch?v=8lMK9...o_ypTTKEV7pLX7sigpic
Fresh, if you look closely on the springs themselves, they are marked "Front" and "Rear".
In a dot matrix like font.
Not easy to see unless you know it's there.
Your thrid spring from the left and 5th coil down from the top shows some markings.
I just can't make it out at the resolution of your pics.
Update: after loading your pic to Paint and zooming in.
Your 3rd sping from the left ID definitely labeled as "rear".Last edited by Pu241; 05-08-2013, 03:43 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I noticed the front and rear label, its the top and bottom I'm wondering about. The coils are wrapped tighter on one end and looser on the other end. I was just wondering if it matters which end goes up.sigpic
He's asking about which end goes up though...not front/rear.
99% sure that they go on as pictured, i.e. the top of the pic goes to the top hat. With the rubber piece that goes onto the spring itself. The flatter end goes onto the bottom spring perch. If you have another Festy :-) , you can confirm this by comparison.
Edit: John did not supply the wrong answer, you just asked the wrong question! :highly_amused:Last edited by TominMO; 05-08-2013, 04:17 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
^ HA 8^) Maybe these pics will help. The coils on one end are spaced 1" apart. The coils on the other end are spaced 1 1/2 apart.sigpic
Another way to put it: the end you can stand the springs up on without falling over is the bottom of the spring.
Edit: the more I think about it, I think I have it wrong. Flatter end goes on top, with the rubber isolator piece. Just try it out: one will seem right, the other won't.Last edited by TominMO; 05-08-2013, 05:05 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I'd put the soft ones(the ones spaced closer together) on the bottom. Small bumps that aren't enough to move the stiffer coils could be absorbed by the softer ones without disturbing the ride as much, if I'm thinking correctly. If this is how they work, putting the stiffer bunch on top should remove a tiny bit of unsprung weight and make it that much easier on the soft springs to do their job. If the soft coils are completely bound on installation it probably makes no difference either way.
This is theory in my brain. Not experience talking.
EDIT: Just saw the post above mine. Less thinking, more feeling. Good.Last edited by sketchman; 05-08-2013, 05:09 PM.Any difference that makes no difference is no difference.
I read somewhere the tighter coils go up top. That's where i have mine.
Edit: just ran outside and looked at them. On the back the top 4ish coils are completely compressed. I have a 75ish pound speakerbox inthe trunk On the front the top 2.5-3 Coils are compressed. Tighter coils on top.Last edited by Chobobulous; 05-08-2013, 05:22 PM.
^ correct.Trees aren't kind to me...
The back springs will stand on either end . I'm going with the (tighter) narrower spaced coils on top. Thank you everyone for your input, I didn't want to do it twice. I'm wrong 85% of the time with 50/50 chances.sigpic
