First you need studs and lug nuts
Then you remove brake caliper and rotor. So you don't strip the 2 set screws in rotor use hammer and impact wrench.
Find a drill bit that you need and size up next to wheel stud to make sure it isn't bigger. And drill the hole out
Insert stud in hole. Use washer and lug nut and gently tighten. And take it slow so you don't snap the stud. And get it flush in the back.
