So I did the Rio swap and gained about 7.5lbs at each corner. Went up 10mm in tire width and nearly nothing in diameter. Verified both with an online calculator and a tape measure.
The majority of that weight is in the wheel/tire package. It went from about 21lb 155/80/12 on steelies to 25.8lb 165/60/14 on 11.8lb alloys.
I've lost about 5 mpg consistently after this. It feels slower to accelerate to me, but I'm willing to believe that's in my head and quite possibly just feels that way because it's smoother now.
The fuel economy decrease, though, has held steady with every tank after the swap. I even use the same pump at the same station every time.
I read the following and started to think some.
http://www.w8ji.com/rotating_mass_acceleration.htm
The simple thing I take away from it is that with the swap, I added weight in the worst place I could have. In the tires.
Old tires weight approximately 10.5lbs each. New tires weigh 14lbs each. Old wheels are 10.5lbs. New wheels 11.8lbs.
So 1.3lbs in the wheel but 3.5lbs at the tire. The place that'll store the most energy before it moves.
Now that's got me thinking. What would happen if I stuck some 12lb 13s on with 155/70s? The TINY bit of added weight in the wheels moves toward the center of rotation a touch to offset it, and the diameter and width of the tire goes back down to almost stock, along with surely loosing weight in the tire too.
Thinking when it's time for more tires, it'll be time for more wheels too.
Thoughts?
Thoughts?
