Will these wheels fit? Still trying to sort this out.
A zero offset is going to stick out the side of your car like a quad rollerskate
those are actually a 12.9 mm offset. But yeah, they will not clear the fenders without some serious negative camber. 185 55 14 tires will fit those rims, but they are going to poke out of the fenders quite a bit.
14x6 is a common stock size rim, so you have alot of options that will fit a Festiva. Look for some 14x6 86-89 rx7 base model alloys. They look kinda like those welds, but will fit the Festiva and should cost a lot less (they will be much heavier though).Last edited by Advancedynamix; 07-08-2013, 08:42 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
In the over view it said this..
Offset: 0.00mm
Where did you see 12.9?
back spacing of 3.5" on a 6" rim = 12.5mm offset.
a 3" back spacing would = 0 offset
remember, offset is from the centerline of the rim, so anything not equal to 1/2 rim width means that there is an offset (+/-)Trees aren't kind to me...
This site abounds with cheapskates.. but that are willing to mortgage their souls just for the sake of 'pretty wheels'. If you've done the Aspire swap (ie better brakes plus graduating to 4 x 100 wheel pattern) then save your shekels and start looking at salvage alloy Rio wheels. They bolt right on and are perfect for offset/hub centric etc, and oftentimes they are available for scrap value, instead of the inflated 'gloss' factor that no one else is willing to pay for further down the road.
