Hey people.
I've been piecing together new suspension restoration/ upgrade parts.
And a small thread on fa.com sparked my memory on needing to also get new coil spring isolators.
Now there aren't any replacements online specifically for our vehicles.
But I found some universal polyurethane coil spring isolators.
They sit on top and on bottom of the coil springs
To isolate them from the spring perch on the struts and where the coil meets the vehicle body.
They may just be to reduce noise but I would like to replace then anyways.
But anyhow I'm not ready to disassemble my suspension yet I still need other parts and pieces.
But I like to order all my parts piece by piece.
Then replace the whole system all at once.
And these are one of the items I would like to order ahead of time.
They would be for the top and bottom of the front a rear springs I believe.
It's been a while since I did the suspension swap on my old aspire
So I'm trying to go off memory here
If anyone has these parts lying around or disassembled currently.
Could they follow this link and take note of the style.
And measurements of the stock ones and reference the ones that would make for the most suitable replacements.
I know these pictures aren't the best but here's a picture of the bottom isolator.
It's the rubber directly underneath the coil spring keeping it off the strut perch.
![](http://i197.photobucket.com/albums/aa96/tigerrawrrrr/IMAG0023_zps9737c81d.jpg)
And here's a picture of the top isolator separating the spring from the body mount.
![](http://i197.photobucket.com/albums/aa96/tigerrawrrrr/IMAG0024_zpsab9bebde.jpg)
The pics don't clearly show it but if you were to go look outside at your own you would see them.
Also if you've ever removed your coil springs you will have reused these pieces probably.
