I have a 1991 Ford Festiva GL with stock rims and tires and need new rubber , but they dont make the size i need anymore and was wondering if these ( http://tampa.craigslist.org/hdo/cto/4108302776.html ) would fit on my bone stock car. if the link didnt work the tire specs are 14x6.5 -10 offset eagle alloys 028's with good tread , could probly get them for 160 bucks for the set , thanks for your time.
Aftermarket wheels
Welcome Florida guy-Greg
Redneck Engineer
FOTY - '09
If that's a -10mm offset, they'll stick out quite far and you may have fender rubbing issues. Tire size is not mentioned and if they are over 185/60 in size they'll certainly be too tall.
I wouldn't recommend them on the extreme offset alone.
At the top of the "custom suspension, brakes, and wheels" forum is a permanent thread called "4 hole wheels" with information on what size tires and rims fit the Festiva. A search on "wheels" will pull up other information and experience. I was lucky to find a local Festiva owner who replaced his stock wheels with Aspire wheels and still had usable 12" tires and rims.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
