In this thread:
I found that attached photo along with this description in a post from F3BZ:
"the spring on the right is the rear spring for the 94 5 door pride. the one on the left is a stock 3 door festiva spring. all dimensions are the same except that the wire diameter for the 5 door spring is 1/2 mm larger in diameter (10mm). when plugged into a simple online spring rate calculator the 5 door spring is almost 25% higher force for each inch of compression. (97 lbs./in. vs 121 lbs./in.). part# KK153 28 011. $25.45 [from FourGreen]"
Would this be an alternative to an Aspire rear beam (for which I've never been able to determine if it can handle more weight than the stock Festy beam) and its different wheel bolt pattern?
