tire size calculator
  • tire size calculator
    205/75-R14 tires are 5.13 inches (130.4 mm) smaller in diameter than 275/75-R15 tires and the speedometer difference is 16.5%
    Was looking to see what tires could fit my car with cutting the finders and found this i t works for all tire sizes so hope this helps and make getting tires easier for you all
    It also shows the spedo speed to actuall speed to !!
    1993 festy "white stallion" BP swap with 7" lift, 1ton wench
    R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
    Good site I going from a 12 to 14 on stock festy and this helps alot
    1990 Red Festiva STOCK "pregnant roller skate"
    1989 Yellow Festiva BP swap "Freebird"
    2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
    2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
    2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
    1994 Ford F150 5.0 Completely stock.
