I have an 89, front struts and rear shocks are completely gone. thought about lowering it w new parts. new springs/struts/shocks. just about a 1" or 2" drop. any suggestions? i don't want to cut springs.
lowering/replacing festiva suspension.
FMS springs are approx 11" in length. I have those on mine and it's got a nice stance with only a small amount of scrub when going over large bumps. You can use Advancedynamic thread and build your on coilovers. That's one option. I'm sure several others will post their opinions.
Since you are talking about replacing the struts, I'd use 2001 Rio front struts with the correct top mount. It gives you a ball bearing on the top instead of the friction ring on the stock Festiva mount.Last edited by Team Lightning; 12-04-2013, 12:12 AM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I second the Rio mounts and struts. You'll need to use either cut Aspire or Rio springs, use stock Festiva springs, use uncut Aspire springs, or go coil over.
Don't combine Rio mounts with Aspire or Festiva struts since the mount center hole is different. You can fab a work-around, but I think that's too much work for no real gain.
Also, this is just for the front. Rio rears are too different to use.
Preceding advice is all good. If budget is low and looking for 'biggest bang for the buck' scavenge springs/struts/top hats (2 hole, not the later 3 hole type) off an early Rio and rear springs/shocks off an Aspire. Cutting springs is not a huge ordeal nor a drudge to install and allows you to carefully tailor the ride. Buzzing off one entire coil ought to get you the height you want and not require you to wear a kidney belt. My experience with now-defunct FMS lowering springs was not as positive as were the cut Aspire springs I have on now. Second the motion to install Rio top hats: truly a great move in order to achieve 'poor man's power steering'!
If time/effort/money is not an object then seek out forum member Advancedynamix posts on suspension modifications; he has sophistication and geometry right down to an art.
I'd still use the Rio fronts along with the Rio top mount even with the stock springs.Jerry
Team Lightning
93 L Lightning. BP
OEM Festys 'corner on their doors' and you always feel like they're about to tip or roll over if you suddenly haul on the wheel at highway speed. Swapping over to Aspire/Rio springs makes a big difference. Uncut springs are going to raise the car about 3/4 inch which isn't so bad if you become a curb hopper like me. Betcha new Aspire(Avella) springs via FourGreen in Korea are quite affordable.
Now that I'm running 175/70-13 snows for the winter (23" dia vs 21" OEM Festy) my DD car actually looks normal.
