Like what size tire you've tried on what width wheel with what offset?
I'm coming down to the point I'm wanting to finally buy wheels and tires for the black GL and I don't plan on doing an Aspire/Rio swap on it. It could use new struts probably and raising it a bit with different springs isn't out of the question.
As I've said before, the speedo is off 5mph slow at 60mph so I'd like to put a taller tire on it. I'm 95% sure I want to go after market on them, new or used. I haven't found any factory wheels locally that I care for, plus i could 4x100/4x114 in the event i change my mind on suspension swaps. The only wrench that might get thrown into this is if I can convince my neighbor with the BP/auto Protege thats langishing in his front yard with the window rolled down to let me have it for $400 for a swap and swoopies. Then the speedo would read different.
so please post up your combos and what mods you've done if they rubbed. In searching for this info, i think it would make a great sticky. Only need tire size, wheel width and offset.
