15" wheel help
  • 15" wheel help
    I have search many of days. I get conflicting facts, theories, truths, etc.
    I need to replace the tires on the car and I want to upgrade. I have the Aspire front brakes waiting to go on. I plan on redrilling AC Delco Festiva Hubs.
    As of now I am running stock Festiva Suspension. Will coilovers be in the future....more than likely no. I am reading that Aspire fronts struts and reusing the Festiva springs are good as well as Aspire rear struts and Festiva springs. Am I correct on this. If so I plan on going with this.
    Now onto the wheel /tire setup. This combo is what I am wanting to go with.
    Wheel AVID AV-02 15x6.5 with +38mm offest and Federal Formoza FD1 165/45/15
    With that being said, Am I going to need/do anything special? Will I need to plan on getting studs? Where and what size?
    I need all the help I can get on this purchase I am or am not about to make.
    If anyone has other recommendations, please speak up, I just want minimal fabrication, cussing, etc. I already do that on my other project.
    Great site plenty of info, I just need it narrowed down abit.
    Thanks in advance,
    Chad
    If you go with Aspire rear struts, use Monroe's. All the rest are the same for a Festiva and Aspire. I had Gabriel Aspire rear units on mine, they have the same number as those for the Festiva. At least they did when I bought them a couple of yrs ago.
    I have studs on both of mine. M12-1.5 50mm long. Use Locktite to keep them in place,Red I believe is the one most people use.
    I'm sure others will give their opinion too.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      Thanks, appreciate the help.
        Going with a different wheel after more research. Drag DR-9 wheel with 165/50/15 tire size. Now I just need to buy some studs and tuner lugs. Anyone know the best/cheapest place to buy. Thanks.
          I bought mine at a local custom wheel shop. Cost was around $35-40 I believe.
          Jerry
          Team Lightning
          93 L Lightning. BP
            I was running 15x7 with 145/40 r 15 ' s on stock suspension and slammed on coils with no issues also you can do an aspire hub swap to get the 4x100 bolt pattern
              Where did you find 145-40-15 tires? Do you have a link?
              Jerry
              Team Lightning
              93 L Lightning. BP
                So, this is what I actually went with. Happy with it.
                  That looks good!!
                  Jerry
                  Team Lightning
                  93 L Lightning. BP
                    Very Nice!!
                      Not a fan of black wheels but I do like the look those give the Festy
                      N3WBI3
                        Black with polished lip RULES!!!!
                        Dan
                          Sweet. I love my DR-9 wheels. They're on my Escort, though. Good cheap wheel.
                            Is this the wheel/tire size you described? Did you end up doing any modification to get it to work? Tomorrow is wheel/tire day for me. Probably maybe
                            Yellow - '91 Festiva L - 5 speed
                              I'm sorry it was a 165/40r15
