Width of Miata Daisies?
  • Width of Miata Daisies?
    Anyone know the width of a gen1 Miata daisy wheel? I'm guessing 5.5".
    Yes it is a 5.5 inch.
      Tominmo, here are a couple pic's of the Daisies I have and really do not know were they fit in the Miata years, but yes they are 5.5
        Thanks all. I was thinking of getting some 165/65x14 tires, and wanted 14x5.5" wheels to put them on, as 14x6 seems less than ideal.
        @sc72, I think the daisies were from 90-93 or thereabouts; 1st gen Miatas.
          TominMO,
          The Blue BP car has Miata Daisies with 165/65/14's on them, if you remember.
          Rubs the driver side rear wheel well in tight turns, primarily because of the FMS springs.
            Originally posted by Pu241 View Post
            TominMO,
            Thanks, I wouldn't be using shorter springs tho, so prob no worries.
              Correct, mine just barely touches and without the lowering springs you should be fine.
                Also, I didn't mention that this would go on my Aspire, so no rubbing issues there since it has a different shaped wheel well.
