Escort wheels
  • Escort wheels
    does anyone know if the 14" alloy wheels on early 90s model escorts will fit the festy? i saw some recently and was just wondering. thanx.
    89 L, hopefully returning from the dead soon with a little more power... :twisted:
    http://www.fordfestiva.com/forums/sh...77-my-89-build
    Search, Search, Search, Search, Search, Search, there's a sticky in the top of this forum with a link to wheels that fit the festiva's.
    No, they wont unless you've done the aspire swap
      I have the aspire swap in the driveway and once its on, I'm probably going with the 14x5 escort wheels, so I'll let you know how it turns out if I can ever find some escort ones cheap. Matts right though, the festy bolt pattern won't fit them only the aspire bolt pattern will work with those.
      No festiva for me ATM...
        I was thinking about getting some 16x6.5 rims, 4x114 of course
        4x114 is the same size as 240 wheels too.
          I have the Aspire swap done on my car. I have a set of 15in wheels from a 93 Escort GT and they bolt up but rub bad with the stock EGT tires
          Paul
          91GL
          Menomonee Falls, WI
            the EGT 15"s are 5 and 1/2" wide though, and the 14" alloys (7 spoke) are only 5" wide, so I don't think they would rub too bad, especially not with a stiffer suspension... my wheels I have now are dual drilled 100mm and 114mm, so I won't necessarily have to swap wheels once I get the aspire brakes on, but I most likely will.
              and am going to use escort wagon wheels, they come in stamped steel so they will look kind of stock, but the wagons had 14x5.5 in so they wont be to big and they will be 5.5 wide like the EGT alloys.
              AIM= bobbo216
                crap... oh well. not like i could get any anyway... :evil:
                  scort alloy wheels are plentiful at the junkyards i go to...
                  im deciding between miata wheels, bmw bbs 30 spokers, or the 16x7 rotas i have lying around
                    Originally posted by festivaWES
                    bmw bbs 30 spokers
                    sounds interesting! what year and model BMW are those from?
                    AIM= bobbo216
                      bmw
                      for fun i put my 4 wheel from my bmw 325 1987... it is BOLT ON
                      on aspire swap or on aspire...
                      yvan
                        318 model late 80's also on some vw jetta/golfs
                        a wheel that will bolt up but the offset is at a 20!!!
                        is the old datsun 280z's 6 spoke might want to get some low pros for it though.
                          will stock escort tires fit under a festiva? anyone got pics of what it would look like?
                          cool thanks for letting me know, i will have to keep my eyes open for those.
                          AIM= bobbo216
