Honda Wheels
  • Honda Wheels
    Hey all....does anyone have any experience with fitting this type of wheel on a Festy?
    92 GL, 98k
    77 Chevy shortbed
    I have no personal experience, but assuming the bolt pattern is right, they'd probably be a good choice. You could contact the seller to find out what kind of Honda they're from and cross reference it to this list to make sure it's the right bolt pattern. Festiva is 4X114.3
    Being from an old Honda, I'm sure they're not terribly wide, so I doubt you'd run into a rubbing issue, but some of that would depend on the tire as well.
    Axlander9289, brother of ThisVelologist
    Festivas past:
    Aqua '92 Festiva L - Sold "Dale"
    White '89 Festiva L Plus - RIP "Dudley"
    White '93 Festiva GL - Sold to thisvelologist "Frito"
    Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
    Current Fleet:
    Aqua '93 Festiva L with Aspire brakes "Dale Jr."
    Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
    White '15 Ford Transit Connect
      Honda normal bolt pattern is 4x100. I can't see the wheels inter webs are messed up. But without an aspire swap normally honda doesn't fit our cars.
      1989 Ford Mustang GT 5.slow
      1996 Ford F-150
        Honda Accord used 4x114.3 wheels from 1990 to 2002. Most Civics were 4x100.
          Those wheels are from a Civic/CRX, if you've got an Aspire swap )4x100 bolt pattern) they will fit with 155/80 or 175/70 tires. They will not bolt up on the stock Festiva hubs (4x114.3). I'd recommend trying to get him to come way down on price, or keep looking for another set, if you really like those wheels. There's enough 13" Civic steelies floating around out there that a bare set with no wheels usually isn't worth more than $50-$60. Unless the market is very different in your area.
          No festiva for me ATM...
            There is this list, on this forum .....
            http://www.fordfestiva.com/forums/sh...ole-wheel-list
            Go down to 4.5 inch (114.3)
            Dan
