maybe this has already been revealed. 90s escort/tracer with 13" wheels use a smaller disc than up level 14" trims. the 13" brake discs are dimensionally EXACTLY the same as the Aspire ATX disc. the only difference is the lack of the 2 countersunk assembly screw holes found on the aspire disc. if you're running ATX aspire discs you might find more performance options by searching aftermarket catalogs for escort/tracer. for example, these power slot cryo treated discs were offered at tire rack for the escort/tracer but not listed for aspire. and due to those 2 screw holes in the aspire disc there probably won't be same part #s between the 2 cars at mcparts.
