maybe this info is in the bowels of the search disfunction. but maybe i can get a qwicker answer with a new post. this aspire (avella) bracket (left) is identical to the festiva except height. the hole for the bushing bolt in the aspire bracket is 7/8" further from the flat part of the bracket that is bolted to the body. if the aspire bracket is used on the festiva will the suspension geometry be changed enough to notice? would the rear of the car sit a little higher? any chance it would contribute to better handling?
