these swaybar lateral locks make sense in my mind but i wonder if there is enough movement in the bushing to where they would be effective. Whiteline seems to be a respectable suspension co.
just more tuner Bling?
Don't know whether they work or not, but they're just split shaft collars. You could get the same thing from mcmaster.com for probably much less.Any difference that makes no difference is no difference.
The way the Festiva suspension is held together, it doesn't really allow the bar to walk from side to side.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
They wouldn't work at all front to rear but could work to lock everything in the center. In other words if you put them at the lower control arm to lock down caster change they would slip but used at the sway bar mount bushings could hold the bar in the center. Cool looking!Reflex paint by Langeman...Lifted...Tow Rig
i'm speculating that if the bar was moving laterally enough to matter you'd see a thin shiny band near the bushing shoulder where the paint or rust was being worn off due to swaybar movement. also these locks would butt against the shoulder of the rubber bushing and not the bracket. the rubber shoulder would have a little crush before lateral movement was truly stopped. there might be less or no shoulder crush if you were using poly bushings. i still think you'd need enormous side forces for these to contribute anything measurable or perceptible . looks cool but i'm voting BLING.
I must update this.
The stock design might not allow any movement, but if you put in urethane bushings with the universal shells, it CAN move laterally. Mine is doing it now with new control arms and brand new urethane bushings all around. It can't get any tighter up front. It's moving enough that I will find a cheaper solution than buying those bling-y things to do the same job, but I do need a solution.Any difference that makes no difference is no difference.
Originally posted by sketchman View PostDon't know whether they work or not, but they're just split shaft collars. You could get the same thing from mcmaster.com for probably much less.
Extra security for aftermarket bushings, high performance mods, and autocross, where high pressure side loads are exerted on the suspension?Last edited by drddan; 07-08-2015, 09:43 AM.Dan
Originally posted by Advancedynamix View PostThe way the Festiva suspension is held together, it doesn't really allow the bar to walk from side to side.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
^Yep, I have the same issues with just a B6-ME swap.
I can see by the grease smears that it's moving a good 3/16" in both directions.
EDIT: Solution. I bought 2, but you could be extra cheap and probably get away with just 1 and welding 1/2 of it on both inner edges of the bushings.
But even 2 is just $10 shipped.
http://www.ebay.com/itm/261430052941Last edited by sketchman; 07-08-2015, 11:11 AM.Any difference that makes no difference is no difference.
Hummm, Yes,
By design, the suspension is compliant laterally by stretching the rubbers (center and end bar mounts, as well as control rod inners). Lateral bar movement was first caused in both Rosie and Trashwagon when the trans cooler lines leaked and caused the center LH bar mount to perish, the RH mount alone not being enough to prevent the bar from moving.
Both cars got aftermarket mounts and Wow, lots of throttle steer and brake steer!
This pic is on Rosie, aftermarket mounts with no lateral control. You can see how far the bar moves.
So I got some shaft collars from my local hardware store (they are 1/2 the price at McMaster Carr, about 5 bucks) and found the bar has too many curves to get two proper mounting points!
I tried an experiment on trashwagon, welding a washer butted squarely to the inside LH mount and fitting a shaft collar to the other side.
This works, but my driving style puts enough lateral load on the bar to bend the mounts!
Next try is to add 1/4 inch thick rubber washers between the abutments and the mounts, but as Trashwagon got totaled, I'll be trying this on Rosie.
As you can see, Mazda went through some trouble to build a system both simple and reliable that works extraordinarily well !No car too fast !
I thought about reinforcing the new shells with some metal welded in but didn't. Might rethink that now.
So really we'd need to convert to bearings up front or use the OEM shaped ones that I'm not sure are available for the Festiva size sway bar. That's too bad.Any difference that makes no difference is no difference.
Anyone with good bar to chassis rubbers should take good care of them!
Charlie, what did you end up with on Tweek?No car too fast !
Ahh, they do exist. Just take a while to get here, and are more expensive than the universal ones.
spf1478-22kAny difference that makes no difference is no difference.
Originally posted by sketchman View PostAhh, they do exist. Just take a while to get here, and are more expensive than the universal ones.
spf1478-22k
IanLast edited by fastivaca; 07-08-2015, 02:57 PM.Ian
