The tires on my festiva are shot time for new ones I want to here from people that are really running 13s on their festy.Lots of wheels have the right bolt pattern but I am not going to have a chance to experiment with off sets spacers back spacing etc. I am going to the bone yard buying 4 wheels driving to the tire store and saying mount balance and put these on my car.What straight bolt on wheels and tires are you guys using.
what wheels are you using
30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.Tags: None
Geo Metro are common for straight to 13" upgrade. As far as tire size, I have 175/70R13's on my car. Speedometer is about %7 slow but more efficient at highway and cruising speeds.Last edited by crazyrog17; 02-22-2015, 10:53 AM.-Zack
If you can only find two Metro 13s, put them on anyway, on the front for the lowered RPMs. I did this for a while, with 155/80x13s on front and 155/80x12s on the rear, and there were no handling issues.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
165s won't rub, but 175s might. I always recommend everyone switch to wheel studs, and use spacers if needed, for the size tire they want.Last edited by TominMO; 02-22-2015, 05:57 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I got the same wheels 175/70/13 is the recommended tire size to not throw the speedo off too muchOriginally posted by TorqueEffect View PostRunning 13" Konig Incidents with 175-70-13s.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
My sig shows my Hyundai 13's. They fit with original bolts and no spacers. I had no rubbing even with heavy trailers, before I lifted it. The one pic is with no spring, looking at suspension limits.Reflex paint by Langeman...Lifted...Tow Rig
