5-6" Drop with VW KYB's Converted to Coilovers?
  • theastronaut
    replied
    I ended up modifying the original bushing cups, they worked out good to support the rubber bushing better. I got them swapped in and have been thrashing it on backroads and on/off ramps this afternoon... I may not drop it any lower if that's going to compromise grip, this is too much fun! The carb'd b3 is terribly inadequate between corners now, might have to "fix" that eventually.
    (saw your motor question in the email notification) The motor is a mock-up 5.3 and T56 with an Inglese Weber IDA intake for LS3 heads. The C10 in the background is my main project, been working on it the past few years. It'll be set up for track and autocross while still being street friendly. Going to use either a LS2 or LS3 (8000+rpm solid roller cam/shaft rockers/ported LS3 heads either way so I can use the intake), a Magnum T56, 2nd gen CTS-V/Brembo brakes, the front has been reworked for better geometry, and a three link in the rear with a Ford 9". Bad thing is, it's still going to be slower than a prepped Festiva around a tight track... hmmmmmm Have you thought of going to any of the Optima/USCA events with a Festiva?
  • Advancedynamix
    replied
    Originally posted by theastronaut View Post
    I could just cut the spring hats down shorter to remove the taper? Or a washer will work. I should have looked at how they mount in the car first I guess... The beam I picked up today has bushings that aren't rotted so I'll use those. Everything inside the drums are in top shape as well. Hoping to get the coilovers on tomorrow, and I've just ordered everything to redo the rear brakes (shoes/seals/cylinders/hoses/axle nuts/etc).
    Do you ever make extra camber spacers to sell? I know you don't do this as a business so no problem if you don't.
    I picked up an '84 Snap On "taco cart" tool box last weekend that's been handy for working on parts like the rear beam. Got the sleeves glued onto the strut bodies and cut down one lower mount on the inside and spaced it over from the outside.
    Yeah, if you've got room to turn those down before you interfere with the register (you'll want at least .125 of meat to register on the top collar on the shaft) that's the best plan.
  • sketchman
    replied
    PORNOGRAPHY!!!! drool
  • theastronaut
    replied
  • Advancedynamix
    replied
    Check Rmoltis's build thread. I think he replaced his beam bushings.
    You may want more surface area on the top of your spring hat. There is a rubber bushing that sets on top of there and you'll want the whole bushing to be supported. Nice work so far though!
    Edit: you may be able to use a washer on the top of the hat to support the bushing.
  • theastronaut
    replied
    I also found a complete rear axle for $40 that I can hopeful pick up this weekend. I have a broken e-brake cable and this is complete drum to drum with good cables. I can rebuild the brakes and swap the whole thing in when I do the coilovers. Are bushings available for the beam? Didn't see them on Rockauto.
  • theastronaut
    replied
    Made one of the top hats tonight. Should I have made them taller? I haven't pulled the stock struts out to see how they mount, I'm guessing there is some sort of rubber mount similar to the front mounts? It has to pivot somehow...
  • Movin
    replied
    Thanks, they likely have less travel as well then too. I have been thinking about doing something with the 88 but making an easier way to lift.
  • Advancedynamix
    replied
    The RSK and all the other zinc coated "Raceland" style coilovers seem to be pretty much the same quality as the racelands. The RSK shocks may actually be a nicer product than Racelands. All the different brands use different style gland nuts to hold the inserts in the strut body, and there are slight differences in the thread length on the body. I prefer the RSK shocks.
    Movin, these coilovers will lower your car, even at the most preloaded setting. They are shorter than stock festiva shocks.
  • Movin
    replied
    This thread title...My stock 4 speed would have air under the tires with a 6 inch drop. The automatic would have a little air under the car but it has 175 13's on stock shocks. The VW Mk II has 6 inch adjusters on my lifted car but the lowest setting is higher than stock. The difference is add on adjusters as opposed to built in. If I replaced my VW mkII stock struts and add on adjusters with these RSK would I lose altitude ? That would be a nightmare! Having a car with less clearance than my chevy 4x4 with super swampers would be embarrassing, restricting, and would make hunting around here even more challenging.
    Where do these RSK coil overs rank?
  • Flyin4stroke
    replied
    I have nightmares about dirty white wheels. You are a mad man!![emoji44][emoji44]
  • Advancedynamix
    replied
    Thanks! They are all dirty now. I love dirty white wheels. They remind me of the Rally cars I used to drool over as a kid.
  • b337yla
    replied
    those wheels are awesome
    Originally posted by Advancedynamix View Post
    Crappy picture I took this morning, it needs more low, but this is with 3" Drop with et25 14x7 wheels with 165/55-14 tires and -3.4 camber with .5 degree toe F/R
  • theastronaut
    replied
    Forgot to update this. I rebuilt the whole front suspension a couple weeks ago and installed the coilovers at the same time. The 125# springs with the raceland's dampening feel good, way less roll and pitch but still rides pretty good. I also found a set of brushed/black center caps to replace the painted caps. I ordered the rear sleeves and springs this week so hopefully I can have the rear finished up soon. It already handles much better, less body roll and tons more grip.
    I also remembered seeing small superchargers being used on VW motors so I looked into them more. Found a few different small superchargers, with an AMR500 looking like the best option for the stock engine. They're cheap and very small, plus inlet/outlet flanges and V-belt pullies are readily available. Once I finish the suspension and get my VW back together I may buy one and start fabbing a mount and intake tubing.
  • azgtx
    replied
    And he talks about old...ya
