struts are all the same across all models. any spring should fit since struts, caps, vibro insulators are all the same. ford shows 5 different springs and 3 differnt wire diameters (.393, .397, .401) leading me to believe that some of the springs that show the same wire diameters might have a different # of coils. ford doesn't show any other info in the parts list other than corresponding color spot for each spring.
kia shows different springs and struts for the 3 door, 4 door 5 door and combi models. i don't have any specs on them but i do know that the 5 door rear spring is stiffer than a festiva and i have a front spring for a combi and it has 2 xtra coils and is 2" longer than a festiva front coil. maybe the combi rides a little higher than the others. something i'll have to look up in the brochures.
) and allow for... less than maximum droop. Idk how much that will be cuz I still need to reduce weight and play with ride height... What is stock travel length? Any way, say I have a fair amount of droop and I'm sliding through a turn and go through dips and bumps. If I have -1*, the change from toe in to toe out should be minimal? And allow predictability?
