shock opinion
  • shock opinion
    disregarding price and shipping costs, which would you recommend or think is a better upgrade over the factory dampers, Bilstein B4, KYB Excel-G, or Sachs ?
    Id like to know too
    Sent from my SM-G920T using Tapatalk
      I've never tried Bilstein or Sachs, I have KYB's on all my drivers. They handle great with the coilovers I'm running.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        For the rear, MK1 VW Bilsteins are the very best, but pricey. A close second, and very reasonable, are the KYBs for the same car. For the front I go with Rio KYBs.
          You know my opinion. I've never tried bilsteins in the rear, but I'm sure they work well. I had bilstein sports in the front and they were very nice. I'm running Sachs super gas coilovers in the front with kyb cabriolet shocks turned coilovers in the rear. It's a very nice package. For comparison, my Festiva is more rewarding to drive than my Cayman S with KW V3 coilovers.
            as this is just a replacement for the original factory installed pieces on a stock AT car i'm shying away from coilovers and other exotica on this car. probably can't go wrong with any of them but my brain, having been washed with the "german engineering" mantra, will probably go with the "steins". thank you for the inputs.
              The coilovers cost 9 bucks a part. Hardly exotica. Lol, especially when your buying 150 dollar a piece rear shocks.
                9 dollars a sleeve, 9 dollars a nut, 39 dollars a spring. You need 2 of each. You'll need to get creative with the spring hats, but it's not that complicated of a part. Then you have rear bilstein adjustable coilovers.
                  German engineering? Have you ever worked on a Volkswagen or Audi?
                    Audi is a nasty 4 letter word. Lol Anyone whose done a timing chain on a b6 S4 knows what I'm talking about.
                      Step 1 - Remove front of car.
                      - Form should follow function...
                        didn't realize how cheap a homemade set of coilovers could be but this project is just a qwik saturday shock change out on an old GF's nice GL. really don't want to see her again too soon after this favor to dial in or experiment with ride height. like she'd care or know anything about coilover suspensions.
                          I just took receipt of a set of Rio Excel -G's to replace the unknown condition Aspire OE struts.
                          Not at the stage of converting those to coil over but considering using the aspire springs vs the festy.
                          Question is should they be cut or used as is? I would like to lower the car but I should figure out its
                          driving dynamics with the Aspire/Rio component swap before I start changing something else?
                            I got those same front struts. I cut my front Festy springs one coil to be more in line with the ride height at the rear. Supposedly the Aspire front (and rear) springs are a little stiffer than the Festy ones. If they are the same height, the Aspire springs will actually raise your car a little, giving you an off-camber effect. Probably only slightly, but still. Personally I'd go ahead and cut the front Aspire springs one coil, whatever you do at the rear. Cutting one coil will not make the struts bottom out.
                            Remember to get good bump stops, especially if you are cutting the springs. These can also be used if/when you convert to coilovers. These are for the rear; I'm not sure they will fit on the front, due to the shaft being thicker. For front bump stops, I'd get these: SB118, from Rock Auto. You can search the part # there.
                              I did notice that the tabs were in significantly different location (& additional) than either the festy or Aspire.
