Originally posted by Advancedynamix
A 7" wheel would have its midpoint at 3.5", right? That midpoint would be 0mm offset. So it seems to me that 3" of backspacing would be 1/2" (12.7mm) outboard from the center, and put the offset at 12.7mm (round up to 13mm).
Or is it that the difference between the outer bead lip and the inner side of the lip is 1/2"? If so, would that explain the difference, and therefore my confusion? IDK if the 7" rim width is measured from outer lip to outer lip, or from the insides of the beads.
