Spacer size needed
  • Spacer size needed
    I am running konig theory 13x5 wheels with 165/65/13 tires which are getting scarce and limited to china tires. If I go up to 175/70/13 it would more than likely scrub due to the wheel offset, does anyone know how much spacer I need to clear the suspension? Are the 1 inch 25 mm spacers the solution or too much?
    We need to know the wheel's offset to answer; but more than likely, one or two 6mm (1/4") spacers would be all you need.
      Hi TominMO thanks for your response. Offset is 38 mm
