My car is a 2000 festiva trio (aspire to the Americas)
I've installed some camber bolts on the front struts in the top bolt holes as per usual. I've adjusted both sides to max negative camber but it looks like it has only worked on the left side of the car. The front suspension is completely stock too which makes me think it might be a warped lca or something like that.
Any ideas what could cause this?
And yes I have installed the bolts correctly with the handles of the washers towards the inside of the car and the lobes of the bolts positioned so they are pulling the tops of the steering knuckle inward.
