I'm planning on sticking a set of Aspire rear brakes on my Festiva rear beam, and have some questions about the process.
1. I know that the Aspire backing plate studs do not exactly line up with the holes for them in the Festiva rear beam. I understand that only two holes in the beam need to be ovaled out to mount up the Aspire brakes. Is this true, and if so, which two? How much ovaling? Does anyone have any pics of this?
2. Do the Festiva hard brake lines directly fit into the Aspire wheel cylinders, or do I need to re-bend them?
3. Can I use the Festiva parking brake cable setup with the connection into the Aspire brakes?
