caliper bleeder broken/difference in auto and manual caliper
  • caliper bleeder broken/difference in auto and manual caliper
    I'm doing my aspire swap and as I was opening up the bleeder it twisted right off. Where is a good place to get a good reman. caliper? I don't know if I really want to get a junkyard one cause then I might have it happen to me again. I'm so close to getting this done and this is the only thing holding me up. Also is there a difference in the auto and manual calipers?
    manual/ auto caliper
    Yes they are different from manual to auto. Autos are slightly bigger as are the rotors, as far as buying a junkyard one, I work at a junkyard and we always crack the bleeder screws for cutomers so they dont wreck them,, A good tip is to heat with a propane torch then splash some cold water on them, ive never had them break doing it this way. Also if your working on a automatc aspire and can't find one try using a caliper from a 91-95 escort, just make shure it has the 13" wheels not 14" or GT,
    1996 Aspire, 2DR 5SPD 185 60 14, Aluminum rims, Mild Stereo system, some neon tubes, 185 000 km not a speck of rust runs like a champ
    B8-ME Swap COMPLETED.
      I tried putting heat on it before it broke but I guess it wasn't good enough. Now I have everything on the car and I drove it to test drive it and the caliper on the right side must be sticking because there was a cloud of smoke when I stopped the car. Do you know of a place to get some cheap reman. calipers?
        Ask for loaded calipers, they come with brake pad on them
