Ah. I tried dropping a magnet between 2 sheets of aluminum earlier after watching that video and it fell like a rock.
Fabricating Custom Suspension?
There ya go bringing rare parts into this conversation William. Up until this point I've only mentioned stuff that any average guy would have.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Since little or nothing is known about the principles involved in magneto reluctance, diagnosing faults can be a problem.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I re bored some knuckles for a Ford Lola once... Guy locked a bearing up road racing.
Cast magnesium.... Insanely light! Felt like holding a styrofoam knuckle. Way lighter than 7075.~Nate
Current cars:
FOTY 2008 winner!
They may have been a forged magnesium part. Forged magnesium would be awesome, but the service life isn't nearly as long as a 7075 part. I like to use 7075 when I want a durable component that I can't justify the cost of a forging. If the part is designed correctly, it can be nearly as light as magnesium, but much less expensive and more durable. Magnesium deteriorates faster.Last edited by Advancedynamix; 03-01-2017, 08:04 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
It may have been a forging, i just remember it looked like a casting. Ive never really looked into the strength to weight of mag vs al; while custom billet knuckles etc are within my reach i cant imagine finding them necessary! It would be cool no doubt. Could easily scan an aspire knuckle, shorten the tierod boss to quicken the steering up and lower the lca boss to make a 'drop' knuckle.~Nate
Current cars:
FOTY 2008 winner!
^ Yes! Yes, all of that!!!Trees aren't kind to me...
X2!Originally posted by FestYboy View Post^ Yes! Yes, all of that!!!
This ultra light front end would only make sense when combined with a whole list of other similar mods. This would be on a car that was being built to go beyond the scope of any racing class.
Having pushed the limits in an 1800lb 180hp Festiva, I get the chills thinking about what could be done with a 300hp, 1200lb Festiva with a longer TQ curve. This really gets my heart pumping.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
If such a project were to be undertaken, and you couls have anything you wished, what would you aim for? 1" lower balljoint boss? 25% shorter tierod boss? Anything else that could be changed?
Note that im not looking to start such a project in the near future, but its fun to think about!~Nate
Current cars:
FOTY 2008 winner!
25% would be a huge difference at the wheel. I've always wondered about the Saturn SL LCA as an option for the Festiva... Just not sure how the chassis would react.Trees aren't kind to me...
I think we could lower the strut mounting by ~1" before running into axle clearance problems as well, which should allow lower ride height without sacrificing strut travel. Could build in a default -3* of camber by moving the upper strut mounting hole slightly, and could widen the hole spacing up to match the VW strut spacing without having to mod them.
How about readily available (and not crazy expensive) light weight brake calipers? Ideally something that would clear a 13" wheel, or at least 14". I'm sure Wilwood or Brembo makes something that would work... on cars this light I don't think we need much more braking force (4+ piston with huge rotors blah blah) but a radial mount opposed piston might be nice, though I don't think we'd have the wheel clearance we need. Radial mounting would allow use of a 9.25" aspire rotor for normal use but simple spacers could move it out for bigger rotors. Main benefit IMO would be reduced weight, you guys probably know better.
I guess we should identify the main goals:
1. allow lower ride height without running into suspension limits or getting out of the suspensions "sweet spot".
2. reduce weight, especially un-sprung weight.
3. quicker steering, even with a manual rack. The festiva power rack is ~30% quicker than the manual rack, that's what I have in my car and it's amazing, but could probably be a bit quicker for track use. By making the knuckle 25% quicker you would have the option of using a manual rack for street use (and still being able to park it without being the hulk) or use a rio or festiva power rack for track use.Last edited by skeeters_keeper; 03-03-2017, 08:57 AM.~Nate
Current cars:
FOTY 2008 winner!
I would alter the design to use a sealed spherical bearing pressed into the knuckle, rather than into the control arm. This allows for lighter control arms that are easier to make and they could even be adjustable.
Also, rather than make the knuckle bolt up to a coilover shock, I'd integrate it into t he strut tube. This saves weight and actually makes the product less expensive, as the threaded strut tube could be welded into the knuckle. 2 12.5" pieces of aluminum tubing with 1 late op is cheaper than a set of MK2 coilovers, and wayyyyy lighter.Last edited by Advancedynamix; 03-03-2017, 10:08 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
