Originally posted by ryanprins13
festiva rear beam independent suspension
I knew i had just saw it...1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Does the ackermann remain the same when you do a rio spindle swap onto a festy? The rio uses a sealed brg correct? can you use the whole kia strut assembly spindle and all and substitute festy springs? I've only been using this car as a cheap beater to get mpg, but for what it will sell for as a beater when I no longer need it, I am thinking I might just keep it and build a cheap beater turbo car to play with. :]Last edited by ricko1966; 08-31-2017, 04:33 PM.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
