I was one of the people that bought a set of the Fender Braces that Rick made. Very nice design and construction!
I have wanted to make some form of shock tower stiffener but everything I had seen or sketched up was coming out like a moon rocket. But when I was test fitting the braces, the light bulb went off on how I could tie the shock stiffeners to the fender braces.
Basically you just use some heavy sheet metal (same thickness as the fender brace mounting pads) and fab up one piece that will fit on top of the shock tower and be secured in place by the shock bolts and another piece that mounts on the opposite side of the forward most mounting pad of the fender braces. These two pieces of metal need to be welded together.
A major tip - don't cut the big shock tower hole out with a saber saw -- go and buy a big hole saw!! It will save you hours of work and will look much nicer when finished.
I plan on buying some all thread to make "long bolts" that will replace the fender brace bolts that secure the big pad (on the left side of the picture) to it's backing plate onto the car. The extra length will go thru into the engine bay where they will secure the shock tower brace to the car and fender brace.
Still a work in progress (just started it yesterday) but a very easy addition.
I'll get more pictures during the week as the project moves along.
