So, our Festivas don't a proportioning valve, which, with the spring resistance in the drums, means the front brakes will apply first, which is good for trail braking. How differently does the car handle after the rear disc swap?
Questions About Performance of Stock Brakes and Rear Disc Swap
A mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82 -
I think the general consensus is that you don't want rear disc, they lock up too quickly with the lack of rear weight. I think Charlie has even ran without rear brakes at all before.Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
Charlie has stated that he's recorded better lap times with no rear brakes. I'm running 100% stock brakes except for a Miata booster/master cylinder and the rear brakes may be benificial on an autocross course to make the car rotate better. Depends on your application. I know that I wouldn't want any more rear braking power than I have now, it'll already rotate at low speeds, and I'd hate to hit the brakes at higher speed and have it try to swap ends from too much rear brake bias.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Originally posted by Sid_RallyX_82 View PostSo, our Festivas don't a proportioning valve, which, with the spring resistance in the drums, means the front brakes will apply first, which is good for trail braking. How differently does the car handle after the rear disc swap?Trees aren't kind to me...
Originally posted by FestYboy View PostA well sorted drum system will apply just before or at the same time as the front. Having the front apply first increases the likely hood of rear lock up due to weight transfer. A good system will make the whole car sit down.A mechanic knows how; A technician knows why.
Originally posted by Sid_RallyX_82 View PostI don't know of any way to make a system do that without a proportioning valve
I would guess at most there has been maybe 2 or 4 people who have done a rear disc swap.
Originally posted by Sid_RallyX_82 View PostI don't know of any way to make a system do that without a proportioning valveTrees aren't kind to me...
Originally posted by FestYboy View PostIt's all about the shoe to drum clearance...A mechanic knows how; A technician knows why.
Originally posted by Sid_RallyX_82 View PostBut wouldn't the springs in the drum setup retain the shoes until the front Pistons have expanded to engage the pads? I imagine that it would be a reasonable task force to have all clearances minimized before actually driving the car, but what about on the 3rd lap in a race? Surely the braking attitudes would change with use, right?
So, we apply pressure to the system via the master. Since it's hydraulic, all points of the system experience the same pressure at the same time. Therefore, the rear wheel cylinders will see no delay when the master is depressed. The perceived delay has everything to do with the difference in take up between the front and rear, and the volume of fluid required to "fill the gap" front and rear.
Compared to the hydraulic pressure available from the master, the drum shoe springs are worthless. The only reason for them is to retract the shoes once hydraulic pressure is released or parking brake cable is released.Trees aren't kind to me...
Originally posted by ryanprins13 View PostI didnt quite understand your original question so i didnt say anything, but why do you not want to use the proportioning valve?
Originally posted by FestYboy View PostYou need to remember that you're using a hydraulic system... And that the square seals in the front pistons are what gives a gap to the front pads... Which is not adjustable. The gap to the rear drums however is...
1) the pad to disc clearance, which would need to be filled before there is enough resistance to overcome the shoe springs
And 2) when the shoe liners wear, the breadth of the shoe-drum clearance falls in the hands of the star adjuster and how finely it can adjust, which I assume its increments are fairly wide
But if everyone agrees stock drums are better than a disc swap, I'll keep with thatA mechanic knows how; A technician knows why.
Originally posted by Sid_RallyX_82 View PostI just don't want to go through the effort of adding in a proportioning valve and tuning it.
My concerns are
Concern 1: the shoe springs are pretty light springs and are most likely being moved while the front piston is moving.
An easy way to check what would happen is to remove front caliper and rear drum. Have someone else very very slowly start pushing the brake pedal, you watch the front caliper and someone else watches the rear shoes and see what happens.
Concern 2: its not a star adjuster on threaded rod like trailer brakes or something. Its a self adjusting mechanism with very, very fine teeth. Lots of fine adjustment there i believe. I dont have a photo unfortunatly, but there was a for sale thread for an adjuster recently which had a photo.
*edit* found the thread from febuary but it was a photobucket photo and is gone.
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 07-31-2017, 03:06 PM.
Originally posted by ryanprins13 View PostOk, i didnt realize the oem one wouldnt work.
Sent from my SM-G920W8 using TapatalkWill Samet
How to find me:
Originally posted by w4rkry View PostPM me Ryan and I can recover it really quick, while it's relevant haha
https://fordfestiva.com/forums/showthread.php?t=60067
1) good idea. Wouldn't have thought of that.
2) oh, I've haven't had to change my rear brakes, so I've never seen what it usesA mechanic knows how; A technician knows why.
